Wistia Video Thumbnail
EIS CAPS 30 F FANUC CRX Cobot Palletizer Thumbnail
EIS Automation
CAPS-30F Cobot Palletizer
  • Start palletizing on day one
  • Suitable for all pallet types
  • Up to 30Kg payload
  • Up to 8 cases/min (single pick) (higher with multipick)
  • Easy to use tablet operation
  • Easily movable
CAPS-30F Collaborative & Advanced Palletizing System
Throughput up to 8 cases per minute (single pick)
Stack height up to ~2000mm (78.75”)
Power requirement 120VAC, 15A
Compressed Air Depends on End-of-Arm tool
Payload up to 30Kg (66lbs)
Overall Dimensions L3650mm x W2000mm (143”L x 79”W)
Repeatability 0.05mm
Reach 1756mm at 30Kg, 1889mm at 25K
Options ✓ End of Arm Tools (single/multi-zone) ✓ Case Coding/Label (print on demand, label or direct print) ✓ Positioning Conveyor (1m or 2m, auto start/stop) ✓ Traceability / Data (1D/2D code & OCR) ✓ 3 Laser Scanner (Dual Zone) Safety System
