Fuse Automation
CRX 10iA/L Glue Dispensing Application
The CRX 10iA/L Glue Dispensing Application is a collaborative robotic system built to automate adhesive application with precision, safety, and scalability. Powered by the FANUC CRX 10iA/L robot, this solution is ideal for manufacturers struggling with inconsistent manual glue application, labor shortages, and rising production costs.
Many customers face challenges such as:
  • Inconsistent Glue Beads – Manual application often leads to uneven lines, affecting product quality and causing waste.
  • High Labor Costs and Turnover – Skilled operators are hard to retain for repetitive glue tasks, creating training and downtime burdens.
  • Production Bottlenecks – Manual processes can’t match the speed or reliability of automated systems, leading to missed throughput targets.
  • Messy Workspaces and Downtime – Leaky applicators and poor control systems result in frequent cleanups and maintenance delays.
  • Limited Floor Space – Traditional automation solutions take up valuable real estate that smaller shops or lean operations can’t spare.
  • Safety Concerns – Using industrial adhesive systems near human workers can pose risks without proper containment or separation.
This solution directly addresses those pain points with:
  • A compact, easy-to-integrate robot with built-in safety sensors—no fencing required
  • Precision dispensing head with customizable paths and flow rates
  • Foamed adhesive integration from Fuse Automation to reduce material usage and weight
  • Simple HMI and teach pendant interface, making it easy for any operator to control
  • Modular design that can adapt to different parts, lines, and adhesive materials
The CRX 10iA/L Glue Dispensing Application brings reliability, repeatability, and efficiency to your production line, reducing waste and increasing consistency.
  • High Throughput – Optimized for fast, continuous adhesive application with minimal downtime
  • User-Friendly Interface – Simple HMI and teach pendant controls for easy setup and operation
  • Compact Footprint – Space-efficient design ideal for production lines
  • Precision Dispensing – Accurate path following and consistent glue volume control
  • Flexible Integration – Compatible with a wide range of nozzles and foamed adhesive systems
Dimensions, Footprint, Reach
Table 8x8
Reach 1418mm
Throughput
Parts a Shift ~1000 parts
Power Requirements
Power Requirements 120V
End of Arm Tooling Type(s)
Tooling Type(s) Dispense Tool; H200 0 Cavity
Safety
Safety Light Curtains; Fencing
