Wistia Video Thumbnail
Nav thumb for fanuc 640x480
Navigator Double Cage V2 LH Back ISO
Navigator Single Cage
APT
MOD-WELD Navigator Cobot Welding
The MOD-WELD® Navigator™ is a mobile robotic platform that brings automated welding and/or cutting directly to the workpiece. Built with the FANUC CRX‑3iA collaborative robot, Miller® Auto‑Deltaweld® or Hypertherm® Powermax125® power supply, this portable, modular platform reduces material handling, minimizes setup time, and increases production flexibility by delivering robotic welding/cutting wherever production demands it, up to 100ft. Single or Dual Platforms to configure the system to meet specific production requirements. The single-platform configuration includes one FANUC CRX-3iA collaborative robot, while the dual-platform configuration includes two FANUC CRX-3iA collaborative robots.
  • Deploy the cobot to the work area, ideal for large or difficult‑to‑move workpieces
  • Increase production flexibility by delivering welding wherever production demands it, up to 100 ft.
  • Portable, modular platform reduces material handling, minimizes set up time
  • Designed to be magnetically mounted to floors, walls, or ceilings
  • Single and Dual platforms available to best fit your application
  • Industries served: Shipbuilding, heavy fabrication, structural steel, rail, pressure vessels, energy & offshore, rail manufacturing, energy and offshore and many more
  • Software Options: FANUC TPW (Touch Sensing, Through ARC Seam Track, Root Memorization), FANUC Shape Gen
MOD-WELD Navigator Specifications
Reach 692 mm (27 inches)
Payload 3 kg (6.6 lbs)
Single Platform Dimensions 72.19" L x 53.75" W x 64.44" H
Dual Platform Dimensions 72.19" L x 53.75" W x 75.75" H
Single Platform Approx Weight 1700 lbs
Dual Platform Approx Weight 2100 lbs
Power Requirements 120v 20 amp
Safety cage to protect the Navigator, Anchor points design to connect to a crane's rigging hardware to safely move the Navigator.
