IC Automation
SmartPallet 1000
The SmartPallet 1000 Mobile Palletizing System is engineered to simplify end of line palletizing while delivering reliable and consistent performance. Designed as a compact and mobile automation platform, the SmartPallet 1000 helps manufacturers reduce manual palletizing, improve throughput, and maintain consistent stacking quality without the complexity typically associated with traditional palletizing systems.
The SmartPallet 1000 combines a FANUC CRX collaborative robot, intuitive HMI, and compact mobile base to palletize finished products directly at the end of production lines. Operators configure pallet patterns through the touchscreen interface, position pallets and product, and the SmartPallet manages the stacking process with accuracy and repeatability. Preconfigured routines allow for fast setup and simple changeovers, making it easy to adjust for different products, pallet patterns, or line requirements with minimal input.
With built in safety features and true mobility, the SmartPallet 1000 can be redeployed across multiple lines or facilities as production demands change, maximizing utilization and reducing downtime. The result is a practical and scalable palletizing solution that delivers immediate productivity improvements while allowing teams to focus on higher value tasks instead of repetitive manual labor.
  • Compact, Space-Saving Design
  • Dynamic Palletizing for Mixed Cases
  • User-Friendly HMI for Simplified Operation
  • Built-In Safety Features
  • Scalable Configurations for Any Workflow
  • High-Speed Automation for Increased Throughput
SmartPallet 1000 Specifications
Dimensions 136" x 50"
Power Requirements 120VAC
Safety Keyence Area Scanner for Speed Adjustment
