- Cobot Devices
- 3D.EasyTeach
Includes CRX Plugin
No
3D.EasyTeach
Sensors
3D.EasyTeach is a no-code teaching solution for robotic paint applications. It allows skilled painters and operators to guide the process manually, while the system records the motion using infrared tracking technology and converts it into an optimized robot-ready paint program. Adjustments can be made directly in the software for fast refinement and repeatable results.
Includes CRX Plugin
No- Eliminates manual programming
- Ensures consistent, high-quality coating
- Fast and easy no-code teaching
- Turns painter movement into robot programs
- Works for small batches and changing parts
- Teach new parts in under 10 minutes
3D.EasyTeach Specifications
| Max. field of view | 3 m height: 2 x 2 m ground |
| Max. range | 5 m |
| Tracking accuracy | +/- 1 mm |
| Max. speed in line tracking | 10 m / min |
| Tool | II 3G Ex c IIB T5 Gc, II 3D Ex c IIIC T5 Dc |
| Power Requirements | 110 V UL-normal Power Requirements |
Atex Markings: certification ongoing, markings may be subjected to changes
