3D.aero GmbH
HP-FX
Sensors Software
HP-FX is a high-precision robotic surface inspection system designed for aerospace MRO and industrial applications. Using the advanced 3D measurement technology and intelligent automation, it quickly detects surface defects, coating issues, and damage with micrometer-level accuracy. The system works on nearly any material or surface shape and delivers fast, repeatable inspection results without the variability of manual inspections. By combining industrial robotics, white light interferometry, and smart analysis software, HP-FX helps companies improve quality, reduce inspection time, and increase maintenance efficiency.
Includes CRX Plugin
No
  • Fast, automated inspection that reduces cycle time from hours/days to minutes
  • High-precision, µm-level accuracy for reliable quality control
  • Consistent, repeatable results that eliminate manual variability
  • Seamless integration with robotic systems for increased productivity and digital records storage
  • User-friendly shop floor operation
HP-FX Specifications
Dimensions L × W × H: 140 × 90 × 180 cm
Weight Approx. 250 kg
