Cobot and Go: Sanding That Delivers Craftsmanship at Scale
- Published
- Last Updated
- Reading Time
- 2 min
Contents
Faced with ongoing labor shortages and the physical demands of manual sanding, woodworking manufacturers are in search of smarter, more consistent finishing solutions. Enter the Rapid Series Sanding system from Vention—an advanced, plug-and-play automation solution featuring the FANUC CRX-30iA collaborative robot and PushCorp rectangular sanding tool. Designed to reduce dependency on skilled labor, this turnkey system delivers uniform results across diverse panel types and cabinet designs while scaling effortlessly to meet growing production demands.
Woodworkers can now find the system included in FANUC’s Cobot-and-Go web tool, featuring ready-to-deploy systems for a variety of applications, including cobot sanding.
Precision Meets Simplicity
To deliver consistent, high-quality finishes across varying cabinet sizes and designs, Vention’s Robotic Sanding Solution eliminates the guesswork and variability common in manual sanding. Its compact, plug-and-play footprint fits effortlessly into existing workshop environments and operates using standard 120V power outlets and air lines, enabling manufacturers to deploy quickly without costly infrastructure upgrades.
Smarter Sanding, On the Floor
This intuitive system empowers operators with accessible software to create and refine sanding “recipes” directly on the shop floor. With real-time adjustability and process visualization, manufacturers gain greater control over finish quality and repeatability—no coding or robotics expertise required.
Optimized for use with 3M™ abrasives, the solution ensures professional-grade results while reducing operator fatigue and the inconsistencies tied to manual workflows.
Remote Support & Reliability
Production uptime is a top priority. With comprehensive remote support with response time within 10 minutes for troubleshooting and maintenance, manufacturers can resolve issues swiftly and keep operations running smoothly. This proactive approach to service helps businesses stay focused on growth rather than downtime.
Find this and many more pre-engineered collaborative solutions using the FANUC Cobot-and-Go solution finder.
