Assembly Machine Tending/Part Transfer Material Handling Material Removal Packing Palletizing Picking Sanding
Cobot Combo
Cobot Combos make automation simple by letting you choose the right FANUC CRX robot for your application and pair it with the exact services you need—programming, tooling, installation, training, and support. This “choose your robot, choose your services” approach removes guesswork and streamlines deployment, giving you a customized cobot package that gets automation into your shop faster and more efficiently.
Assembly Machine Tending/Part Transfer Material Handling Material Removal Packing Palletizing Picking Sanding- Streamlines the automation setup process for faster ROI
- Fast setup with pre-engineered cobot bundles
- Automates repetitive tasks to boost productivity
- Flexible for tending, inspection, and assembly
- Reduces labor strain and workforce challenges
- Safe, affordable entry point into automation
